1989 Oldsmobile 88 timing
1989 OLDSMOBILE 88
115,000 MILES • 6 CYL • FWD • AUTOMATIC
CUSTOMSLOTCARS
I want to order a timing chain set. i see both a three bolt and a single bolt cam pulley listed for the 3800 motor. how do i know which one i need?
Jul 14, 2010 at 2:30 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
The only way to be 100% certain on which you need, you will want to pull the front timing cover/ water pump off to visually inspect it. It will either have a counterbored bolt hole or three bolts.
Jul 14, 2010 at 3:53 AM
