1989 Oldsmobile 88 oil pressure
1989 OLDSMOBILE 88
567,754 MILES • 6 CYL • 2WD • AUTOMATIC
EMCHAY
just changed the oil, when the car is idling pressure is 60 when i accelerate the needle on the oil pressure gauge goes all the way past the highest reading on the gauge
May 30, 2010 at 12:03 PM
  • 31,937 POSTS
OK, i would get the oil pressure tested with a mechanical gauge, if it is going sky high you will have a stuck pressure relief valve.
mark (mhpautos)
May 30, 2010 at 1:36 PM
