1989 Oldsmobile 88
PAGE169
Noises problem
1989 Oldsmobile 88 6 cyl Front Wheel Drive Automatic
how to change a harmonic balancer
Nov 10, 2010 at 7:48 AM
JDL
  • 16,098 POSTS
Whatever is easiest for you? It may be the easiest to remove passenger side front tire, go at it that way. Safely raise and support the vehicle. I remove the belt-- remove pulley bolts, if it still won't come off, I use a puller. I'm an old man, I do it the easiest way possible.
Nov 10, 2010 at 8:06 AM
