1987 Oldsmobile 88 trouble codes
1987 OLDSMOBILE 88
RICKJR57
Computer problem
1987 Oldsmobile 88 6 cyl Two Wheel Drive Automatic
checked for codes think they are 12 and 25
Nov 25, 2009 at 6:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
code 12 simply indicates that you have correctly entered the onboard diagnostic system.
code 25 is for MAT sensor signal voltage low , most likely caused by a faulty or failing MAT sensor.
Nov 25, 2009 at 6:19 AM
