1985 Oldsmobile 88 charging
1985 OLDSMOBILE 88
92,000 MILES • V8 • 2WD • AUTOMATIC
NASCARFAN88
i have replaced the alternator and battery twice a new plug in for the alternator new batt bolts new cables, good ground wire, conn are clean and tight, and yet the charge light still comes on.. what can cause the alt not to charge?
Jan 31, 2010 at 6:49 AM
JDL
  • 16,098 POSTS
welcome to the forum. If you have a digital voltmeter, take a reading across the battery posts, everything turned off. The generic spec for a full charge is 12.6 volts. Start the vehicle take a second reading across the battery posts, the second reading should be higher than the first, if the alternator is charging. Engine running, you can also take a reading at the alternator bat terminal, just don't get the leads caught in belt or pulleys.
If not excite voltage, the alternator won't charge. If there is a problem with the wiring circuit between the alternator bat terminal and battery, possible, no charge.
Jan 31, 2010 at 7:04 AM
NASCARFAN88
i don't have a meter to test the voltage but i have had it tested and although i didn't ask what it was reading they said it was weak?? i was talking to my brother who is a mec he said try the coil in the dist.. why i didn't think of that along time ago i dunno. but after some thought i realized that this just might b poss. i did a complete tune up to the car a few months ago, but i forgot to buy a new coil.. so like a bone head i took off the old one and put it in the new dist cap.. the charging prob happend shortly afterwards.. but before i go and buy one i am gonna take it down to my parts store and have it checked out.. hopfully this will cure the prob, if it don't then i'm gonna sell it come spring time.. thanks for all your help..
Feb 1, 2010 at 5:42 AM
