1984 Oldsmobile 88 short grind when starts
1984 OLDSMOBILE 88
MATRIXSCUBA
Noises problem
1984 Oldsmobile 88 V8 Two Wheel Drive Automatic
had advanced check the alternator, said was fine, to check the starter teeth or the flywheel teeth.I cannot afford a repair service so i am trying to fix the problem myself.When the car starts there is a very brief grind noise.suggetions?
Feb 7, 2010 at 4:32 AM
  • 110,240 POSTS
I would say either the teeth on the flywheel or starter are bad or the solenoid is delayed on engaging the starter to the flywheel (which could lead to damage). Remove the starter and check it out. Have the parts store bench test it to make sure the solenoid is working properly and not sticking.
Let me know what you find.
Apr 15, 2010 at 2:45 AM
