1966 Oldsmobile 442
FRED DAVIS
  • 1966 OLDSMOBILE 442
Electrical problem
1966 Oldsmobile 442 V8 Two Wheel Drive Automatic
i need to wire a neutral safety switch. I have a console floor mounted. I have found the wires that break in p and n but need to know where to tie them in to the wiring harness.
Tuesday, October 12th, 2010 AT 9:31 PM
WRENCHTECH
  • 20,761 POSTS
There will be a wire coming off the ignition switch that gets hot in "start" position only, usually yellow that goes to the neutral switch. The wire coming back out of the neutral switch, usually purple, will go to the "S" terminal of the starter.
Wednesday, October 13th, 2010 AT 7:48 AM
