Hi there,
I let my old truck sit for three months without trying to start it, and when I try now, it will not start.
Before letting it sit it was starting and running beautifully.
When I turn the key the engine turns over like normal but just does not start. The gas gauge starts moving up like normal etc.
These are the things I have tried so far that have not worked:
*Adding fresh gas.
*Adding HEET to gas tank.
*Spraying carburetor with a little starter fluid.
*Giving it a jump from another car.
Something I noticed today is that when I try to start the truck there is not any gas entering the fuel filter that is in line heading to the carburetor. The reason I know that is because the fuel filter is one of those clear glass ones.
I am guessing that this might mean the fuel pump is out. What do you think?
Is that something that might happen by letting the truck sit?
Thanks!
Micah
*Adding fresh gas.
Thanks!
Micah
Jul 31, 2017 at 10:21 AM
