There are loose wires everywhere?
300,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
OLLIE2022
  • 49 POSTS
By the hitch and on the passenger rear green, blue, yellow, and black wires with no connection like someone cut them? Is there a diagram for this?
Dec 2, 2022 at 2:41 AM
  • 110,251 POSTS
Black is the reverse lamps, yellow is for the left signal and stop lamp, and dark green is for the right-side signal and stop lamp.
I am not seeing a blue wire. There should be a white wire for ground and a brown wire for the parking lamps.
I attached the entire exterior lighting circuits below. See pics 1 and 2. I also zoomed in on the trailer wiring in pic 3. Confirm there is a blue wire. If there is, turn the parking lamps on and see if there is power to it which turns off when the lamps are turned off.
Let me know what you find. Also, here is a link you may find helpful:
Dec 2, 2022 at 3:11 PM
