Oil tank drain plug removal
230,000 MILES
MIKE BOLOURI
Hello, please tell me what size socket head is needed to remove the oil drain plug for the vehicle listed above. This isn’t mentioned in the video which is very helpful.
Mike
Sep 24, 2019 at 2:15 PM
SCGRANTURISMO
  • 4,897 POSTS
If it hasn't been changed by somebody, it should be a 14MM hex head M12 X 1.25 bolt. It should be torqued down to 111 inch/lbs. or between 9 - 10 ft/lbs.
Thanks,
Alex
2CarPros
Sep 24, 2019 at 6:49 PM
