Where is the oil stick located?
153,000 MILES • 7.5L • V8 • 2WD • AUTOMATIC
DEMBER3110
can't find the oil stick or possible hole for one.
May 22, 2022 at 9:33 AM
  • 110,244 POSTS
It should be on the driver's side of the engine about two thirds back on the engine block. See pic below. If you still don't see it, check on the engine block itself to confirm it isn't broken. These were known to rust into the tube and when removed, they would break.
See pic below.
May 22, 2022 at 2:39 PM
