Yes, an oil change will never hurt a car. It can only help. If the oil in your vehicle isn't that old though, you can simply drain a half quart or so of it out and get the level where it is supposed to be. Either way I would recommend that you bring the oil level down to where it is supposed to be because if you run too much oil you risk possibly damaging bearing, oil pump, and at the most risk of failure would be your gaskets, mainly your oil pan,front and rear main,head, and valve cover gaskets. I have included a couple of links down below for you to go to:
https://www.2carpros.com/articles/high-oil-pressure
https://www.2carpros.com/articles/how-to-change-engine-oil-and-filter
Please go through these guides and then get back to us with you decide to do.
Thanks,
Alex
2CarPros
SPONSORED LINKS
Thursday, March 21st, 2019 AT 5:39 PM
