Oil sensor dinging but no light?
200,000 MILES • 3.8L • 6 CYL • 4WD • AUTOMATIC
GREG MAYES2
The sensor for the oil is dinging without a light coming on. It does it around curves and when you stop at a stop sign or when you take off. Is my oil low but no light coming in?
Jul 12, 2023 at 5:08 AM
MATHGEN
  • 128 POSTS
I would check the oil level before driving again. If you are due for an oil change, I would go ahead and have that done. They should inspect for any leak at that time. As far as the warning light goes, the bulb in the dash may be burned out. When you turn the ignition key to on do you see the oil light come on? Please let me know what you find out.
Jul 13, 2023 at 12:52 AM
