Oil is leaking out of valve cover gaskets. BAD! No power. Exhaust fumes'll make ur eyelashes curl up. Runs super hot al the time. I understand they're known for that and I've had 3 cars previously with more or less the same motors but this 307 runs super hot. Someone mentioned cleaning the drain back holes. Not sure if its something I should get into cause not real sure it's the problem
Mar 28, 2015 at 3:58 AM
