Oil seal break-in time and oil loss
100,000 MILES • 2.3L
JAMES GLINSKI
  • 10 POSTS
How long does it take for a new rear main oil seal to seat and stop leaking oil? a month? What should my oil losses be during that time? thanks, Jim
PS. I sent you guys a new picture of that pipe ninple coming out of my engine down inside my passenger side motor mount it's steel no rubber associated with it .again thinks, Jim. happy motoring.
Jun 7, 2020 at 5:21 AM
STEVE W.
  • 15,377 POSTS
A new seal shouldn't leak at all from the time it is installed. There is no break in time. A seal that leaks is either not installed correctly, the wrong seal or the shaft it is riding on has damage. The normal issue is that the area the seal rides on gets a groove worn in it and the new seal doesn't fit properly because of that and it leaks. For that you can sometimes install the seal just a bit farther out or in so the seal doesn't ride in that groove, another repair is called a speedi-sleeve, that is a thin stainless sleeve you press into place over the worn area so the seal has a smooth surface again. The last resort is replacing the worn part, with a crankshaft the first two options are a bunch cheaper and easier.
Another common reason for seal leaks is a bad PCV system. The crankcase should have no pressure in it but because of blowby from the cylinders it has pressure in it. The PCV system is there to collect those vapors and oil mist and send it to the intake to be burned off. They can get plugged with oil or the hoses get blocked and now you get pressure in the crankcase, that can be enough to cause a leak.
I would check the PCV system first as it may have caused the issue for the first seal.
Jun 7, 2020 at 6:43 AM
Good afternoon.
It should stop immediately if it was the seal.
Did you make sure the PCV system is working? If it is not there will be too much pressure and the weakest seal is the rear main.
Did you check the surface of the crank for any grooves? Also, a bad rear main bearing will allow it to continue to leak.
Jun 7, 2020 at 6:44 AM
JAMES GLINSKI
  • 10 POSTS
PCV? It seem to stop I checked the smooth rear crank and found nothing. I'm still losing some oil but it's not as bad. not from that area it seems when I park I look under when I leave and there's very little on the ground. that steel pipe coming out of my motor mount area seems to be the problem, but I haven't really driven it very much yet to be sure of anything. thanks, Jim .
Jun 7, 2020 at 12:09 PM
JAMES GLINSKI
  • 10 POSTS
I don't think it was a groove smooth rear main. what happen was I had pulled back the flywheel plate to turn the teeth on the flywheel and didn't replace it back with bolts dirt and mud got up in there and trashed the seal. I live in a very muddy place. it's right now. thinks, Jim
Jun 7, 2020 at 12:16 PM
You are welcome.
Always glad to help.
Jun 7, 2020 at 6:43 PM
