Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Plymouth
Voyager
Engine
Symptoms
Oil Leak
Oil seal leaking
1998 PLYMOUTH VOYAGER
188,000 MILES • 3.0L • V6
ELDER JULIAN BURNS
MEMBER
1 POST
Oil leaking out from bottom front!
Dec 24, 2019 at 1:17 AM
Experienced Mechanic
More then likely this is the crank main seal but here is a guide that will help with oil leaks:
https://www.2carpros.com/articles/engine-is-leaking-oil
However, if this is the crank seal here is a guide that will help with replacing this:
https://www.2carpros.com/articles/front-main-seal-replacement
Also, I attached the procedure from the manual below that will help replace this. Let us know if you have other questions. Thanks
Images (Click to enlarge)
Dec 24, 2020 at 10:12 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
