Oil pump replacement?
175,210 MILES • 3.0L • MANUAL
PJ1000
oil pump priming procedure
Jul 17, 2026 at 6:20 AM
PJ1000
Vehicle details: Standard Transmission
Jul 17, 2026 at 7:53 AM (Merged)
  • 55,845 POSTS
If you've replaced the oil pump, rebuilt the engine, or the engine has been sitting dry, it's a good idea to prime the oiling system before starting it.
1. Remove the camshaft synchronizer
2. Insert an oil pump priming tool (or an old synchronizer shaft with the gear removed) into the oil pump drive.
3. Attach a 1/2-inch drill.
4. Spin the pump clockwise (the normal operating direction).
Let me know if you need anything else.
Jul 18, 2026 at 7:59 AM
