Oil pump pickup screen
200,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MLINTON2
  • 15 POSTS
Hi everyone.
I'm getting frustrated and need your help.
I have a k1500. I'm putting a new oil pump in it and having trouble getting the oil screen where it should be. I've been told that it should be 3/8 to 1/2" from the bottom of the pan. I've installed two screens so far and both have been high. This last one will be 1" high if I leave it that way. I've measured the depth of the pan and subtracted 3/8" from that. Installed the pump and measured from the block where the pan bolts on down to the distance I got after subtracting 3/8", marked the tube and pump, installed the screen into the pump to where the marks still line up with the screen tube clear in. Did all that with no gasket on the pan. Put the pump on the block and checked distance from screen to bottom of pan by taping different size bars to the bottom of the screen and put some grease on it so I could tell if they were touching. Went clear to 7/8" before it touched. Plus, when I put the gasket on it will end up being close to 1".
I don't know how deep the oil is in a four quart pan don't know if the screen will be submerged when going up or down hill's so I don't pick up air or not.
Don't know what I'm doing wrong.
What do you guys think?
May 17, 2019 at 10:04 AM
  • 110,248 POSTS
Welcome to 2CarPros.
I just went through the directions and there is nothing listing the height. Tell me, is the pick up tube and screen the same as the one you removed? If it is, it should be fine.
Here are the very general directions listed in the manual:
REMOVAL & INSTALLATION
1. Remove oil pan as described under OIL PAN.
2. Remove pump to rear main bearing cap bolt, then the pump and extension shaft.
3. Reverse procedure to install. Ensure bottom edge of oil pump screen is parallel to bottom edge of oil pan rails. Tighten oil pump to rear main bearing cap bolt to specifications.
Let me know if the pump is the same length as the original. If it is shorter, they may have just give you the wrong pump. If it is the same as the original, it should be fine. Just make sure the pick up tube / screen is parallel as mentioned in the directions,
May 17, 2019 at 1:41 PM
MLINTON2
  • 15 POSTS
Thanks Joe for the help.
The new pump is 3/16" taller than the old one.The screen is the same as the old one. These screens are a press in tube fit. I talked to Melling, maker of the pump and screen, and they said that the screen has to be 3/8" to 1/2" off of the bottom.
I got it taken care of.
Thanks again
May 20, 2019 at 12:31 PM
  • 110,248 POSTS
Welcome back:
What did you have to do to fix the issue?
May 20, 2019 at 12:44 PM
MLINTON2
  • 15 POSTS
The screen has a tube that is part of it. I had to get a new screen and install it in the right position. On this kind of pump the screen doesn't bolt on, the tube is pressed, or hammered into a hole in the pump. You have to measure and figure out just what position the screen has to be in to get it in the right position in the oil pan.
It's not a parallel to the bottom of the pan position. You adjust it until the screen is 3/8" to 1/2" off of the bottom of the pan. So the screen is actually pointing a little bit down toward the bottom of the pan.
If you put into google "92 chevy k1500 5.7 oil pump screen installation" it should bring up a video on YouTube of Melling, the maker of the pump, showing how to measure and install the screen. It's only two minutes and 23 seconds long. He explains it well.
Thanks again for your help.
May 20, 2019 at 2:34 PM
  • 110,248 POSTS
Welcome back:
Thanks for letting me know. I'm sure this will be helpful to others with the same issue. I did watch the video and never had to do that. It must be a manufacturer specific design. Well, in this case, I was the student. LOL
You take care and feel free to come back in the future.
May 21, 2019 at 11:36 AM
