how do i remove the oil pan?
154,000 MILES • 4.6L • V6 • 2WD • AUTOMATIC
BDFISHER7
how do i remove the oil pan and pump got it unbolted but cannot get it out.
Aug 4, 2023 at 5:42 AM
  • 110,251 POSTS
If this is a 2wd, believe it or not, the manual is telling me to remove the engine. I attached the directions below.
Are you able to lift the engine enough to remove it? What is it hitting that prevents you from removing it? Let me know.
Also, I attached the directions below. Take a look at them and let me know your thoughts.
joe
Aug 4, 2023 at 2:53 PM
