Oil pump issues?
220,000 MILES • 3.8L • V6 • AUTOMATIC
CHUCKBEATS
Car shut off while running. Later discovered that the engine was not getting oil. Previous to this incident I changed my spark plugs wires and a core pack.
Jan 2, 2023 at 4:58 AM
CHUCKBEATS
Car still starts and engine hasn't seized but makes a ticking noise.
Jan 2, 2023 at 5:41 AM
  • 110,251 POSTS
Did this happen right after the spark plug/coil replacement? Also, is it possible for you to record the engine running and upload it for me to hear? That may help me.
In the interim, double-check if the ticking could be coming from a loose spark plug or if one may have been cross threaded.
If the check engine light is staying on while the engine is running or flashing, let me know that as well.
Take a look at this link. It describes different engine sounds and possible causes. Let me know why you feel there is no oil circulation as well.
https://www.2carpros.com/articles/engine-noises
Jan 2, 2023 at 12:01 PM
