Oil pump gears?
153,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
TJMOWBRAY
  • 85 POSTS
I took the oil pump off for cleaning and one gear fell out. How do they go back together with the two circles together?
Dec 7, 2024 at 12:56 PM
  • 110,248 POSTS
It has been a long time since I had one apart. I believe what you are referring to is correct. There should be two marks that align.
Could you take a couple of pics of the gears so I can see them? Whenever I did this in the past, I would always mark the gears so I could get them back together in the same position. In this case, I want to be sure.
joe
Dec 7, 2024 at 2:05 PM
  • 55,711 POSTS
Can you tell us happen with this?
Apr 29, 2025 at 5:02 AM
