Oil pump should I do the same?
365,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
HADENSIZEMORE
Hello! I will be building a LM7 5.3 here soon and I've been watching your series to get a base on what i'll need and a how to. I just have one question, in your series you used a standard Melling oil pump, should I do the same? I was under the impression that a high-pressure standard volume would be the way to go. I'd hate to mess it up so I was wondering if you had any reasoning behind it. Thank you!
Jun 8, 2025 at 3:05 PM
RYAN L
  • 273 POSTS
Thank you for watching the series!
Depends on what you are building. If you are building a regular hot street engine, the standard pump is just fine.
But if you are building a hardcore race engine you might want a higher volume pump. However, I have also talked to people that run race engines and want a less powerful oil pump due to engine oil sheer. You will make more power with less oil PSI basically.
Between you and me the oil pump I used would be fine for nearly all applications. Thanks for using 2CarPros!
-Ryan
Jun 9, 2025 at 3:47 AM
HADENSIZEMORE
Thank you! I appreciate the Information. Have a great week!
Jun 9, 2025 at 7:13 AM
  • 55,732 POSTS
RYAN L is one of our best! Use 2CarPros anytime, we are here to help. Please tell a friend.
Jun 11, 2025 at 1:28 AM
