Oil pump removal
170,000 MILES • 3.0L • 4 CYL • 2WD • AUTOMATIC
PAUL EKNOY
I can't remove the oil pump from crankshaft. It won't come off.
Nov 23, 2019 at 3:06 AM
Okay. Which portion are you saying is stuck to the crank? Can you get the cover off or is it one of the drive gears?
I included the process on how to replace this in case you see something that you may have missed.
Let me know what portion is stuck and we can go from there. Maybe get some pictures. Thanks
Nov 23, 2019 at 6:57 AM
