oil pump
203,985 MILES • 1.5L • 4 CYL • FWD • AUTOMATIC
MEL SAMUEL GINEVERUS
I repaired the engine, just after two days i have a flash of the oil pressure. i bought a new oil pump after forty five minutes of running the oil pressure is one more time flashing.
Mar 15, 2017 at 2:22 AM
HMAC300
  • 48,601 POSTS
by flashing I am assuming it blinks when you come down to an idle. Most of the time this is bearing wear or sometimes oil filters especially Fram are prone to this. with your mileage. i would probably say it is bearing wear due to miles. you can try a heavier weight like 10w30 if you are not using it already, but no heavier than that.
Mar 15, 2017 at 4:55 AM
