Oil pressure too low?
80,000 MILES • 1.6L • TURBO • MANUAL
ALEX FLETCHER
So, my car keeps juddering when driving like it wants to stall. Sometimes it cuts out completely and then has a warning message saying 'stop oil pressure too low'
I took it to the garage today and he did a full oil/filter change.
He also said that this could be because of blocked fuel lines. It does seem a little better when driving but has still cut out/juddered a few times.
I'm really confused.
Aug 12, 2022 at 4:06 AM
  • 55,649 POSTS
This could be because of a vacuum leak, or the fuel filters need to be changed. This is a diesel engine, correct? Check for a vacuum leak when the engine is cold. Also, we should service the throttle body.
These guides can help us fix the problem:
When the engine idles too low or stalls the oil pressure warning is normal.
https://www.2carpros.com/articles/stall-at-idle
Let us know what happens and please upload pictures or videos of the problem.
Aug 12, 2022 at 5:56 AM
