Oil pressure switch location?
140,000 MILES • 1.4L • TURBO • 2WD • AUTOMATIC
TOBA47
I've been searching online for sometime now and i cant seem to find the location of the oil pressure switch. Could somebody please help me with this ? Its an 2012 Jetta (A6). The car has been blinking the oil pressure warning (red), but i've still been driving it for over 3months now. The car runs the same as always, so i thought maybe its the oil pressure switch? The oil pressure stays steady at 90, but i cant think of anything else that might be the problem. Warning light only comes when the engine has been sitting for a while, 8hrs maybe. And it only comes in the start of the drive, and goes away in few minutes, and doesnt come for the rest of the day anymore.
Apr 13, 2026 at 12:58 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
If the red oil-pressure warning appears, stop safely and switch off the engine. Arrange assessment rather than assuming the replacement switch has resolved the warning. Have actual oil pressure and the warning circuit checked against the service information for the engine code. Confirm the replacement switch's application and record whether the warning recurs. The owner's location description is not a substitute for the matching component diagram.
Guidance references and applicability
2CarPros: Original discussion 1712558 https://2carpros.com/questions/oil-pressure-switch-location-66314531 Source for the owner's reported history and outcome. Contributor suggestions are not independently confirmed diagnoses. No attachment content was verified. Volkswagen: Red engine-oil-pressure warning https://www.volkswagen.co.uk/en/owners-and-services/my-car/warning-light/engine-oil-pressure.html Supports stopping safely and switching off the engine for a red oil-pressure warning. It does not identify the switch or prescribe pressure limits for this engine.
Read the replies · Discussion summary and reported outcome
  • 55,710 POSTS
Yep good call, it sounds like the oil pressure sensor is bad, here is the location so you can swap it out, you may need a special socket to remove it BTW. The sensor is near the oil filter. Can you please doble check the engine size, also is this a euro car?
Apr 14, 2026 at 12:59 AM
TOBA47
Yeah its an 1.4 tsi euro car. I have 225 000 km on it. The sensor in all the videos are near the filter, but i cant locate it. Maybe its different in us and europe.
Apr 14, 2026 at 1:05 AM
  • 55,710 POSTS
Thanks for letting me know, it is described as being under/behind the intake manifold area. Use a flashlight to inspect and let me know.
Apr 15, 2026 at 12:29 AM
TOBA47
Got the pressure switch replaced yesterday. Fairly easy job, just needed a longer socket to tighten the switch in place. It was located at under some pipes on the right side of the engine. Only found it trough the single wire that was plugged in. Didnt need to go under the car. Thanks for the help!
Apr 18, 2026 at 8:54 PM
  • 55,710 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Apr 19, 2026 at 1:30 AM
Discussion summary
The owner of a European-market 2012 Volkswagen Jetta 1.4 TSI described a blinking red oil-pressure warning after the vehicle had been parked for several hours. The discussion focused on locating the pressure switch. The owner later reported replacing a single-wire switch accessible from above beneath pipes on the right side of the engine.
Reported outcome: The owner reported replacing the switch but did not explicitly report that the warning stopped.
The reported reading of '90' had no stated units, source or test conditions and cannot establish adequate oil pressure. The export does not establish the exact switch specification or a completed pressure test.
Read the original discussion
