Oil pressure switch location
135,000 MILES • 2.7L • 6 CYL • TURBO • AWD • AUTOMATIC
SHARONDA WARD
Is it easier to change from underneath the car or by removing driver side headlight?
Aug 23, 2017 at 11:20 AM
STEVE W.
  • 15,418 POSTS
If you are going after the pressure unit above the filter it is easier from under the car. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Aug 23, 2017 at 1:05 PM
