I have an oil pressure sensor performance code. When my friend who's a mechanic put his computer on to check the performance it was reading the oil pressure was 149.6 psi. He said there's no way that's right, so the sensor has to be bad. I'm sure that's true. I'm going to explain what is happening. Every now and then my oil light would come on when I start the car. I would turn it off and restart and the light was gone. I drove home from work and the car was ruining perfectly fine parked for the night. Came out in the morning to a crank no start. My question is, could the sensor being bad prevent the PCM from allowing it to actually start? Everything else seems to be fine. It's getting spark, you can hear the fuel pump come on, and there is gas going into the engine because I opened the Shrader valve and gas came out.
Dec 30, 2022 at 4:24 AM
