Where is the oil pressure sensor located?
145,000 MILES • 2.0L • TURBO • AUTOMATIC
AXLE928
Trying to locate the oil pressure sensor on the car listed above turbo 2.0 base model. Thanks in advance!
Jul 12, 2023 at 11:17 AM
  • 55,770 POSTS
The engine oil pressure sensor is located near the starter motor. Check out the images (below). Please let us know if you need anything else to get the problem fixed.
Jul 13, 2023 at 5:52 AM
