Code P05321, where is the oil pressure sensor located?
74,000 MILES • 1.4L • 4 CYL • AUTOMATIC
RODPDP
Receiving a P05321.
Jan 12, 2024 at 1:56 AM
  • 110,251 POSTS
Please confirm the engine size for me. Is it a 1.5L? They offered three different engines. See pic 1 below.
If it is the 1.5L, it could be in one of two places. I attached pics showing locations. Take a look and let me know if they help. Additionally, the code should be a P and then 4 digits. Please confirm that for me as well.
Take care and I'll watch for your reply.
Take care.,
Jan 12, 2024 at 11:44 AM
RODPDP
Yes, it meant to type 1.5 liter.
Jan 12, 2024 at 11:45 AM
  • 110,251 POSTS
No problem. I just wanted to make sure I was getting you the right information.
If you have a chance, let me know if you can find it. If you do, the connector can be a pain because there is a locking tab that you will need to slide out before you can release the connector. Just take your time so nothing breaks.
Jan 12, 2024 at 12:23 PM
RODPDP
So it is under the alternator, right?
Jan 12, 2024 at 12:59 PM
  • 110,251 POSTS
Yes, it may not be directly behind it, but it should be in that general area.
Let me know if you find it.
Jan 12, 2024 at 1:36 PM
