Oil pressure sensor location
100,000 MILES • 5.7L • V8
JIMMY68
Showing low oil pressure at idle. when moving oil pressure fine.
Jan 2, 2019 at 2:44 AM
Good afternoon,
The sensor is down on the left front of the engine by the oil filter. I attached a picture for you to view of the sensor location. you need a special socket to loosen the sensor. you can get it at the parts store.
As far as the low pressure, it could be the sensor but to be sure, I would check the pressure with a manual gauge to verify. if you have low pressure it could be an oil pump or clogged pick up screen in the oil pan. you can rent a tester at a parts store.
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Jan 2, 2019 at 3:17 AM
JIMMY68
Thank you so much I appreciate it and I will have the oil pump and filter checked out as well.
Jan 2, 2019 at 4:53 AM
You're welcome.
Always glad to help.
Jan 2, 2019 at 5:41 AM
