Oil pressure sensor location
50,000 MILES • 6 CYL • FWD • AUTOMATIC
JAY1511
I am looking for the oil pressure sensor on my car listed above it has the v6. The engine oil light stays on so I want replace it.
Apr 25, 2017 at 12:59 PM
HMAC300
  • 48,601 POSTS
see picture for location A/C compressor may be in way so check as picture is no accessories on it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Apr 26, 2017 at 12:04 AM
RMOELKE
  • 5 POSTS
Sometimes after car is driven for awhile, the oil light tries to flicker on.
May 17, 2019 at 12:38 PM (Merged)
  • 75,988 POSTS
Oil Pressure Switch (3.0L 2V)On right rear of engine block.
Oil Pressure Switch (3.0L 2V FFV)On right rear of engine block.
Oil Pressure Switch (3.0L 4V)On left front side of engine block
PHCLUB
where is the oil presure swith located and is this a simple replacement?
  • 110,248 POSTS
It should be near the oil filter.
PHCLUB
[quote:a6fb1a240d="Jacobandnickolas"]It should be near the oil filter.[/quote:a6fb1a240d]
Thanks for the answer, I did find it on the top of the engine, on the right rear (facing from front), close to the firewall.
  • 110,248 POSTS
I'm glad you found it. They like to make it easy to find things (LOL).
Take care and let us know if you have questions in the future.
