oil pressure sensor location
95,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
FUSIONFIX
locate and replace the oil pressure sensor.
Mar 24, 2018 at 1:33 PM
STEVE W.
  • 15,409 POSTS
It is just above and to the left of the oil filter. Remove the underbody cover if it has one. Then remove the oil filter to get a bit of room for the wrench. Remove the electrical connector and unscrew the sender. Apply a bit of teflon thread sealant to the new one and screw it in, tighten to around 10 ft lb and reconnect the wiring. Install a new oil filter. Reinstall the underbody cover.
Mar 24, 2018 at 3:20 PM
FUSIONFIX
Mar 25, 2018 at 10:46 AM
