Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Challenger
Engine
Oil Pressure Sensor
Oil pressure sensor socket
2006 DODGE CHALLENGER
120,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
STARLORD1976
MEMBER
Purchased oil pressure sensor socket it fits the new sensor, but it doesn’t fit the original in car. What do I need to get it off, it is bigger?
Nov 2, 2021 at 7:26 AM
SQM
Experienced Mechanic
First of you have listed the vehicle as a 2006 Challenger (Dodge did not make the Challenger in 2006, so I am assuming it is a 2006 Charger?).
Those 5.7 the sensor should need a 1-1/16-inch oil sensor socket.
Is that the size you got?
Are you able to get a wrench on the sensor?
Images (Click to enlarge)
Nov 2, 2021 at 10:30 AM
STARLORD1976
MEMBER
Yes, it’s a Charger, the 1-1/16 fits the new sensor but the old sensor on car is bigger some reason.
Nov 2, 2021 at 8:10 PM
SQM
That is strange. Are able to use a wrench or the space is too tight?
Nov 2, 2021 at 11:41 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
