Engine will not stay running?
150,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
RICO71
My car cranks and starts for about 3 seconds and shuts off. I noticed that it doesn't have a pigtail connected to the oil pressure sensor and it's full of oil. Could that be the reason why it won't start? Thank you
Jun 15, 2023 at 12:54 PM
  • 55,770 POSTS
Yes, if the PCM does not see oil pressure it can shut the engine down. Is the sensor disconnected for some reason? Can you see the pigtail?
Jun 16, 2023 at 3:50 AM
RICO71
I can see the 3 wires that I assume it's where the pigtail was supposed to be connected.
Jun 17, 2023 at 3:05 AM
  • 55,770 POSTS
Yep, three wires, here is the connector and how the wires should be connected.
Here is the connector on Amazon:
https://amzn.to/3qQb9cW
Jun 19, 2023 at 2:53 AM
RICO71
Oh, this is perfect let me get my kid off his bed and phone I'm going to start on this and definitely let you know the outcome. Thank you
Jun 19, 2023 at 4:50 AM
  • 55,770 POSTS
You are welcome.
Jun 20, 2023 at 8:17 AM
