Oil pressure sensor
200,000 MILES • 6.2L • V8 • 4WD • MANUAL
DCVZFOX
  • 13 POSTS
I bought this truck used and the oil pressure sensor is hard wired and needs replaced it has the 3 prong sensor. So my question is which wire goes to which prong the wires are red orange and white. The orange wire is hot when I turn the key
May 15, 2018 at 1:12 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Those are not the color wires I see. I see a orange, pink/black and tan. The tan actually being for the gauge, the orange, pink/black for the override for the fuel pump relay.
Can you double check the VIN number and post it? Plus double check the engine number and post it because maybe this is not the original engine.
May 15, 2018 at 1:26 AM
DCVZFOX
  • 13 POSTS
Okay, it might be pink and on the sensor the is one silver prong and two brass ones. The silver is in the middle. Which wire goes to which prong?
May 15, 2018 at 1:30 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I do not know. Like I said they are not the wire colors I see. Can you double check the VIN number and engine?
May 15, 2018 at 1:35 AM
DCVZFOX
  • 13 POSTS
You said you found a orange pink/ black and tan wire. Can you tell me which wire goes to which prong. I am not currently around the truck or I would give you the vin number.
May 15, 2018 at 1:42 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
My manual does not show the sensor prongs, but I can tell you the orange wire should be hot from the fusible link, the pink/black goes to the fuel pump relay and the tan wire is for the oil pressure gauge/light.
May 15, 2018 at 1:47 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
Wait, this is a diesel? Still the same wire colors though.
May 15, 2018 at 1:49 AM
DCVZFOX
  • 13 POSTS
Yea it is a 6.2 diesel with no turbo.
May 15, 2018 at 1:50 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I suggest you purchase the pigtail for that switch, that way you will know where they go.
May 15, 2018 at 1:54 AM
DCVZFOX
  • 13 POSTS
I tried and they all have grey wire so I still will not know which wire to hook to which wire.
May 15, 2018 at 1:57 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
I assume that is a generic pigtail.
I tried looking at photos of switches at Rockauto but still none of the prongs are marked. I suggest you try to get an OEM pigtail or search the internet for anyone else who has had this same problem and found out a solution.
May 15, 2018 at 2:13 AM
DCVZFOX
  • 13 POSTS
Okay, thanks for the help.
May 15, 2018 at 2:16 AM
PATENTED_REPAIR_PRO
  • 1,853 POSTS
You are welcome.
May 15, 2018 at 2:34 AM
