Oil pressure sensor
174,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
JIMMYTONEY
How do I measure output for the oil pressure sensor on my car listed above 300c 5.7l hemi?
Jan 6, 2021 at 7:23 AM
Good evening,
I attached the connector diagram for you. In order to test the output, you need to back probe the signal wire while the engine is running. When you increase and decrease the RPM, the voltage should change between 0 and 5 volts.
Engine, 5.7L/Lubrication/SENSOR, Oil Pressure/Removal
REMOVAL
1. Disconnect and isolate the negative battery cable.
2. Remove the accessory drive belt.
3. Remove the upper generator mounting bolt.
4. Raise and support the vehicle.
5. Remove the lower splash shield retaining bolts (1) and the splash shield.
6. Remove the lower generator retaining bolts (1).
7. Lower the vehicle.
8. Position the generator aside to gain access to the oil pressure sensor.
9. Disconnect the oil pressure sensor electrical connector (1).
10. Remove the oil pressure sensor (1).
Jan 6, 2021 at 8:12 AM
