Oil Pressure Reading at 80
144,000 MILES • 4.3L • 6 CYL • 2WD • AUTOMATIC
DAVID D. AUSTIN II
The oil pressure gauge is always pinned at 80. I would like to know what the most common cause is for this and whether I need to replace the sensor or the oil pump? And I would like to know how to do it. Thanks.
Nov 26, 2016 at 3:48 AM
SATURNTECH9
  • 30,868 POSTS
With the key in the run position without the engine running is the gauge pegged? If so unplug the oil sending unit and see if the gauge drops if it does bad sending unit replace it. Most common issue is the sending unit.
Nov 26, 2016 at 4:31 AM
MATTSCLINE
  • 8 POSTS
Any fix? Same truck, same problem. Unplugging oil sender does not change anything, stays at 80. Pull dash cluster and needle does fall, so I do not guess gauge is bad.
Jul 2, 2018 at 9:45 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I came across your post and found this test for you to check for an open wire to your gauge. Hope this helps and let me know if you have any further questions. Danny-
Jul 2, 2018 at 4:43 PM
