Oil pressure light
105,000 MILES • 2.8L • 6 CYL • AWD • MANUAL
AUDIOWNER18
Oil pressure light was on. Changed pressure switch and now light doesn't come on till 2000 rpm
Mar 29, 2016 at 11:20 AM
CARADIODOC
  • 34,415 POSTS
Do you mean the light is off all the time until a higher engine speed is reached, then it turns on? That sounds like the light circuit is connected to a sending unit for a gauge.
Mar 29, 2016 at 12:45 PM
AUDIOWNER18
Light was on all the time until we changed the pressure switch. Now light is off at idle but comes on at 1800 to 2000 rpm and stays on till you come to a stop
Mar 29, 2016 at 1:30 PM
CARADIODOC
  • 34,415 POSTS
Gotta be the wrong sending unit. Check the actual oil pressure with a mechanical gauge first to be sure it's okay.
Mar 29, 2016 at 2:02 PM
AUDIOWNER18
Will take the car to have pressure checked in the morning. Thanks and will let you know the results.
Mar 29, 2016 at 2:40 PM
AUDIOWNER18
Took car to mechanic. Checked oil pressure and found 15 psi drop at 2000 rpm. Ruled out plugged intake screen and looks like bearing problems
Mar 30, 2016 at 12:10 PM
