Truck runs great but once warm the oil pressure drops and has slight rattle when trans shifts gears.I have been told that its the rod bearings and is common for this motor 2.2.My questions is if I can just replace the rod bearings and fix the problem or should there be more done while the motor is out?I'm just trying to prevent destroying the motor but yet get it back on the road asap and affordable as possible.If other repair should be performed,what would it be?
Mar 29, 2014 at 10:31 AM
