Low oil pressure - engine noise?
200,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
ELI HIX
  • 6 POSTS
Was driving the truck hard and when I parked to turn off the engine shut off by itself. engine does not sound right and oil pressure goes to zero at an idle.
Dec 17, 2020 at 7:35 AM
  • 110,248 POSTS
If the pressure is showing low, do you hear any knocking or ticking from the engine when running? This guide can help us fix it
https://www.2carpros.com/articles/engine-has-low-power-output
Take a look through this link and let me know if anything mirrors what you are experiencing.
https://www.2carpros.com/articles/engine-noises
I'm not sure how hard you were running it, but there is a chance you could have spun a rod or main bearing.
Dec 17, 2020 at 1:14 PM
ELI HIX
  • 6 POSTS
After sitting for an hour or so the oil pressure started coming back but as soon as it warmed back up it was back to 0 at an idle. Has a very noticeable knock at idle also and what sounds like an exhaust leak, but 2,000 RPM's or so all engine noise goes away and oil pressure comes up but not as high as what was normal.
Dec 17, 2020 at 4:45 PM
  • 110,248 POSTS
If you have a knock, it's an internal issue. I suspect a main bearing or one of the rod bearings. Mains can cause a loss of oil pressure.
Is it possible for you to record what it's doing and upload it for me to hear?
Dec 18, 2020 at 2:28 PM
ELI HIX
  • 6 POSTS
Yep, I'll do that first thing in the morning.
Dec 18, 2020 at 2:35 PM
ELI HIX
  • 6 POSTS
This is about halfway to normal operating temperature it gets worse and worse as temperature climbs.
Dec 19, 2020 at 7:19 AM
  • 110,248 POSTS
That sounds like one of the main bearings which would explain the lower oil pressure. We have two choices at this point. Remove the engine and inspect clearances on the main journals and rods which will likely lead to rebuilding the engine or finding a good used engine.
Let me know which direction you want to go and I'll help you get through it.
Dec 19, 2020 at 7:33 AM
ELI HIX
  • 6 POSTS
I've never done a rebuild, but I've always wanted to. However I'd like to build something kind of special and my current financial situation will make that a slow process. So for the time being a good used motor to replace the current one and then starting a rebuild with the block from the motor I pull out.
Dec 20, 2020 at 1:44 AM
  • 110,248 POSTS
I understand. Here is a set of interesting videos you may enjoy. It is the site owner's son rebuilding a 454. This link is part 1 only. They continue after that.
https://www.youtube.com/watch?v=8es2qK6MA_E
As far as the engine, here are the directions for removal and replacement. The attached pics correlate with the directions.
_________________________________
1998 Chevy Truck K 2500 Truck 4WD V8-454 7.4L VIN J SFI
Engine Removal and Installation
Vehicle Engine, Cooling and Exhaust Engine Service and Repair Procedures Engine Removal and Installation
ENGINE REMOVAL AND INSTALLATION
See pic 1
REMOVAL PROCEDURE
^ Tools Required
- J 36857 Engine Lift Brackets
1. Remove the hood.
2. Disconnect the battery negative cable from the battery.
CAUTION: Refer to Battery Disconnect Caution in Service Precautions.
3. Remove the air cleaner duct and resonator from the throttle body.
4. Remove the ignition coil from the intake manifold.
5. Remove the electrical connector at the distributor.
6. Remove the fuel supply lines from the fuel rail.
7. Drain the cooling system.
8. Remove the air conditioning compressor from the engine block.
9. Remove the radiator from the vehicle.
10. Disconnect the electrical connectors on the throttle body.
11. Remove the accelerator cable from the throttle body.
12. Remove the cruise control cables from the throttle body if equipped.
13. Remove the vacuum lines from the engine.
14. Remove the electrical connector from the EGR valve.
15. Remove the generator from the generator mounting bracket.
16. Remove the engine electrical harness and tie out of the way.
17. Raise the vehicle and support with safety stands.
18. Remove the hoses from the power steering pump.
19. Remove the front propeller shaft if equipped.
20. Remove the ground wires from the engine block.
21. Remove the starter motor from the engine block.
22. Remove the flywheel inspection cover from the transmission if equipped.
23. Remove the bolts from the torque convertor to the flywheel if equipped.
24. Remove the exhaust pipes from the exhaust manifolds.
25. Remove the bolts from the transmission to the engine block.
26. For the automatic transmission.
27. For the manual transmission.
28. Remove the engine auxiliary oil cooler lines from the engine block.
29. Lower the vehicle.
30. Support the transmission with a suitable jack.
31. Attach J 36857 to the rear of the right cylinder head.
Install the attaching bolt and washer. Use GM P/N 9428217 with GM P/N 15650963.
Tighten the lift bracket bolts to 40 Nm (30 ft. lbs.).
NOTICE: Refer to Fastener Notice in Service Precautions.
32. Remove the front engine mount through bolts.
33. Remove the engine with a suitable lifting devise.
34. Remove the generator mounting bracket from the engine block.
35. Remove the air conditioning compressor/power steering mounting bracket from the cylinder head.
36. Remove the lift brackets from the cylinder head.
INSTALLATION PROCEDURE
see pic 2
see pic 3
2. Attach J 36857 to the left front cylinder head.
3. Install the engine into the vehicle.
4. Install the engine mounting through bolts.
5. Remove the engine lift hooks from the cylinder head.
6. Install the air compressor/power steering mounting bracket to the engine block.
7. Install the generator mounting bracket.
8. Raise the vehicle and support with safety stands.
9. Install the bolts from the transmission to the engine block.
10. Install the ground straps to the engine block.
11. Install the hoses to the power steering pump.
12. Install the torque converter bolts.
13. Install the convertor pan cover to the transmission.
14. Install the starter to the engine block.
15. Install the oil cooler lines to the engine block if equipped.
16. Install the exhaust pipes to the exhaust manifold.
17. Install the front propeller shaft (4WD).
18. Lower the vehicle.
19. Install the fuel lines to the fuel rail.
20. Install the ignition coil to the upper intake manifold.
21. Install the electrical connector to the distributor.
22. Install the electrical connector to the EGR valve.
23. Install the electrical connectors to the throttle body.
24. Install the accelerator cable to the Throttle Body.
25. Install the vacuum lines to the engine.
26. Install the generator to the generator mounting bracket.
27. Install the air conditioning compressor to the air conditioning/power steering mounting bracket.
28. Install the engine electrical wiring harness to the engine.
29. Install the radiator to the vehicle.
30. Install the Air Cleaner Duct and Resonator to the throttle body.
31. Fill the radiator with coolant.
32. Recharge the air conditioning system.
33. Connect the battery negative cable to the battery.
34. Close the hood.
That's a lot of engine, so make sure when you removing, it's secure.
Let me know if you have other questions or need help.
Dec 20, 2020 at 1:25 PM
ELI HIX
  • 6 POSTS
Thanks for all your help.... Any leads on a good used motor within 100 or so miles of Okoboji, Iowa?
Dec 24, 2020 at 4:31 AM
  • 110,248 POSTS
Not off the top of my head. However, the video I sent is the owner's son. He may. Where are you located?
Dec 24, 2020 at 11:49 AM
