Will no oil pressure make rocker arms come off valves and lash adjusters?
150,000 MILES • 5.4L • V8 • 4WD
SHAWN610641
Oil pressure?
Jun 25, 2024 at 4:29 AM
  • 55,658 POSTS
Yep, if the engine has no oil pressure for a period of time the lifter will collapse and cause excessive clearance in which case the roller fillor will get kicked off the camshaft position.
Here is a video that will help you see what I am talking about:
https://youtu.be/XRdG1ZEUSAc?si=eKPzaJjDGK0bbScS&t=1439
Please upload pictures or videos in your response to any problems so we can see what to help you with.
Jun 25, 2024 at 5:03 AM
STEVE W.
  • 15,394 POSTS
Yes, it could as the lack of pressure could let the adjusters collapse and then the arms are loose so they could come off. However, if there is no oil pressure at that point in the engine, I would be more worried about the damage it is doing to the bearings.
Jun 25, 2024 at 5:32 AM
