Oil pressure
210,000 MILES • 4.0L • V6 • RWD • AUTOMATIC
OHYEA
  • 153 POSTS
My explorer is showing to have the oil pressure gauge to be at no oil pressure. However, the engine runs smooth and drives normal. It has sort of a diesel sound when just idling, there is no check engine light. What should I do? Also when I turn on the car the oil pressure gauge does jump to the middle where it usually is then it drops down slowly to no oil pressure.
Feb 15, 2016 at 7:56 AM
CARADIODOC
  • 34,414 POSTS
Unbelievable. I just updated my web site ten minutes ago to include this problem.
Take the vehicle to your mechanic immediately to have the actual oil pressure tested with a mechanical gauge. If the pressure is okay, replace the sending unit. In the less-likely event the pressure really is low, the engine should not be run until that is solved.
Feb 15, 2016 at 8:13 AM
OHYEA
  • 153 POSTS
I see. what is your website by the way?
Feb 15, 2016 at 8:19 AM
CARADIODOC
  • 34,414 POSTS
We aren't supposed to list links to web sites but you can do a search for Randy's Repair Shop / Welcome. Look at "More Circuit", Ignition System Theory", "Computer-Controlled Ignition Systems", then "Sensors". I just updated that a little while ago but it's far from finished.
Feb 15, 2016 at 9:23 AM
