Oil pressure
OHYEA
  • 1998 FORD EXPLORER
  • 4.0L
  • V6
  • RWD
  • 210,000 MILES
My explorer is showing to have the oil pressure gauge to be at no oil pressure. However, the engine runs smooth and drives normal. It has sort of a diesel sound when just idling, there is no check engine light. What should I do? Also when I turn on the car the oil pressure gauge does jump to the middle where it usually is then it drops down slowly to no oil pressure.
Monday, February 15th, 2016 AT 3:56 PM
CARADIODOC
  • 33,916 POSTS
Unbelievable. I just updated my web site ten minutes ago to include this problem.
Take the vehicle to your mechanic immediately to have the actual oil pressure tested with a mechanical gauge. If the pressure is okay, replace the sending unit. In the less-likely event the pressure really is low, the engine should not be run until that is solved.
Monday, February 15th, 2016 AT 4:13 PM
OHYEA
  • 153 POSTS
I see. What is your website by the way?
Monday, February 15th, 2016 AT 4:19 PM
CARADIODOC
  • 33,916 POSTS
We aren't supposed to list links to web sites but you can do a search for Randy's Repair Shop / Welcome. Look at "More Circuit", Ignition System Theory", "Computer-Controlled Ignition Systems", then "Sensors". I just updated that a little while ago but it's far from finished.
Monday, February 15th, 2016 AT 5:23 PM
