Oil pressure
185,000 MILES • 5.7L • V8 • 2WD • MANUAL
JACKNUT
  • 65 POSTS
0-10 pounds oil pressure at idle, rises to about 30 when I bring rpm's up to about 3,000. No engine noises at all. any way to bring up oil pressure?
Apr 6, 2019 at 10:42 PM
SEVAG P
  • 405 POSTS
It seems oil pressure is at specified value no oil pressure problem you have. check table attached at 1,000 rpm minimum is 6 psi at 2000 rpm 18 psi at 4000 rpm 24 psi.
let us know if more help needed.
thank you.
Apr 7, 2019 at 3:00 AM
