Dash board gauges do not work
176,000 MILES • 1.8L • 6 CYL • 2WD • MANUAL
TRUV17
my gauges on the dash board do not work.. why?
Apr 30, 2018 at 7:32 PM
Good morning.
Check all your fuses with a test light or volt meter for power on both sides with the key on.
if all of them are good, the pull the cluster and check the connector at the back of the cluster. if there is no damage or burned pins then the most likely failure is the cluster itself.
Apr 30, 2018 at 8:21 PM
