Oil pressure?
1.5L • TURBO • AUTOMATIC
TODD ROBINSON
Replace oil pressure switch/sensor brand new no oil pressure reading scanner tells me level good,low high pressure reading good but no psi iam confused how scanner says good ohm's reading good but no numbers? Be for change start engine 25,30 second's and dash board lights up oil light ,and message shut engine off ? This time with new oil filter switch 3,560$ scanner 6 hrs old run test said what was up low voltage this that and the other run car 30 min and no nothing oil light,no matter engine light,no shut engine off run live data says all good but no psi not run.the car monitor said o psi
Oct 22, 2026 at 9:39 PM
  • 55,766 POSTS
I would remove the oil fill cap and use a flashlight to see if the engine is filled with sludge, if so chances are the oil pump pick up is clogged and the oil pan will need to be removed and cleaned. Are there any codes that are stored? The next step is to remove the oil pressure sensor and temporarily install a mechanical oil pressure gauge. This way we can know for sure if the engine is having an issues or if it is electrical. You can rent a manual oil pressure gauge from the auto parts store for free.
Oct 25, 2026 at 8:09 AM
