Oil pressure
190,873 MILES • 5.0L • V8 • 4WD • AUTOMATIC
DELTAP
Cranks up in the morning oil pressure gauge does nothing. 5 to 10 minutes later is runs where it should. Could it be pick up tube? No knocking sounds.
Dec 15, 2019 at 11:27 AM
SCGRANTURISMO
  • 4,897 POSTS
No.If it were the pickup tube that was malfunctioning it would be a constant malfunction and your vehicle's engine would have seized up. The problem is probably with the oil sending unit that sends the signal to the gauge. In the diagrams down below I have included a description of the location of the engine sensors, including the oil sending unit, and a guide to the specified torque value of tightening the oil pressure sending unit.
Please replace the oil pressure sending unit and get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Dec 15, 2019 at 11:51 AM
DELTAP
Thanks, will try tomorrow.
Dec 15, 2019 at 12:03 PM
