Oil pressure light
178,000 MILES • 6.2L • V8 • 4WD
FLIPPINGFOOL
Oil pressure light comes on when I stop and goes off when I get the rpm's up to 700 or put it in neutral.
Mar 4, 2019 at 2:49 AM
Good evening,
The engine idle needs to be at 700. If it is not, then you may have a dirty throttle body.
When the idle is low, the pressure drops and the light could come on.
Mar 4, 2019 at 10:16 AM
FLIPPINGFOOL
It's normally 600 when it is in gear it's 500.
Mar 4, 2019 at 11:12 AM
Got it.
It is too low.
You need to do What I suggested to see if it raises the idle. That needs to be addressed first.
Mar 4, 2019 at 6:49 PM
