Low oil preasure
40,000 MILES
ZAINTAJ787
I completed a service on this vehicle, the oil filter was really worn out. started to clean up the mess inside. made after the service. I started the engine and it said low oil pressure.
Jun 16, 2016 at 4:41 AM
  • 31,937 POSTS
First thing to do is prove the oil pressure by getting a reading with a mechanical gauge, these will screw in there the oil sender fits, get the readings cold idle hot idle and hot 1500 RPM and post readings for evaluation.
Jun 16, 2016 at 7:03 PM
